Browse Forums Finishing Touch Re: Do I really need sealer? 2Mar 03, 2011 2:36 pm As explained to us your paint will start to peel off the walls if not sealed - something to do with lime in plaster bla blah bla. Considering we will live here for a long time we're doing it properly. Re: Do I really need sealer? 4Mar 03, 2011 4:19 pm the fresh plaster is like a sponge - even the oil based sealer was sucked in in a matter of seconds... there are no shortcuts when it comes to painting... Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Re: Do I really need sealer? 6Mar 03, 2011 10:03 pm you might need to check with the paint supplier and find out if there is an acrylic paint which can be applied directly to the render... I'm not sure what's the process for cement render. Might be different. Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Re: Do I really need sealer? 7Mar 04, 2011 12:21 am I'm pretty sure my outside wasnt sealed - but it also doesnt have white plaster. Different story. Re: Do I really need sealer? 8Mar 04, 2011 12:28 pm hey , external cement render needs to cure for 6 weeks to be full cured ( as per spec ) then you can paint if not you can " Possibly " have the problem of moisture of the cement render sweat underneath the paint membrane creating a bubbling effect and cause to peel, blister and flake , however acrylic render doesn't it can be painted the next day so i hear . ( dont hold me to that i havnt read the bag specs ) most External premium paints have a self priming ability so that way you can paint straight onto render . what i would recommend is Dulux aquatex aquasheild now this is a membrane texture. it is far far better than regular paint as it is very thick and allows for greater membrane build allowing for resistance to render cracking. for me its cheaper than weathersheild x10. now for dulux guarantee you can opt for the aquashield sealer, however weathersheild does not require a sealer. its just what your time and budget can afford however weathersheild is an awesome product against peeling fading etc. on a normal house you would benefit from a 3 coat system not 2. possibly cut twice ,roll 3 times looks much better. i would recommend thinning it down a little as it is really thick and opting for a Matt finish not low sheen, on the contrary to what most think external matt finish is just as washable as lowsheen and will allow for better visual effect. ie no sheering shin on render inconstancies . Hope this helps Glenn Re: Do I really need sealer? 9Mar 04, 2011 3:39 pm The sealer will provide a more uniform finish in the look of the final coat. Using 2 coats is ok too, it wont peel of flake...but it wont look as nice as the 1 coat acrylic sealer followed by the 2 finish coats. do not pay until you are satisfied with workmanship windows require flashing over the head archithrave and up under weatherboards 3 28281 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13842 Hello It is good to have a planned bathroom reno to suit your budget and design, living for 10 years I think you need a bathtub 4 10374 |
