Browse Forums Finishing Touch 1 Feb 10, 2011 7:08 pm I want acrylic paint after hearing about the enamel oil base troubles and white paint turning yellow, so what goes where? I want ceiling in white (maybe alabaster) walls in resene thorndon cream trims, door frames and doors in alabaster, but in a shinier paint..like gloss but maybe not so strong, semi gloss? something smooth to the touch, unlike the ceiling. what do I do, and where!? thanks in advance Re: satin/matt/ gloss/flat which paint where? 2Feb 10, 2011 8:20 pm kiwi I want acrylic paint after hearing about the enamel oil base troubles and white paint turning yellow, so what goes where? I want ceiling in white (maybe alabaster) walls in resene thorndon cream trims, door frames and doors in alabaster, but in a shinier paint..like gloss but maybe not so strong, semi gloss? something smooth to the touch, unlike the ceiling. what do I do, and where!? thanks in advance Hi kiwi I have no idea how dark these colours which you want are, but since they are NOT pure white, you might not even notice the yellowing that much on these colours, especially if they are creamy white. Anyway, isn't your builder doing all your painting? If not .... you normally put matt ceiling paint on ceilings. Colour - whichever you want. Walls - I personally prefer "low sheen" paint for walls. All these paints are normally water based. Trims - I always use (highest available) gloss in water based paint. I think it's - glossy ! It is advisable to use glossy paint on trims, doors etc. anyway because the glossier the paint, the better is withstands all the little bumps and kicks. You don't really want to use semi gloss or low gloss on trims for this particular reason. My signature is distracting people from my wise posts ... Re: satin/matt/ gloss/flat which paint where? 3Feb 11, 2011 5:35 am thanks Lex, thorndon cream is like hogs bristle. I didnt want oil enamel on the trims as there is a thread about white oil based paints turning yellow...so acrylic gloss it will be on the doors and trims and skirtings and low sheen on the walls. yep, painter is doing it, but he asked me what I wanted...eeek, I dont know, whatever is best. Hence knowing you guys would know what was best! thanks very much Re: satin/matt/ gloss/flat which paint where? 4Feb 11, 2011 7:03 am Cheers kiwi. My point was, for trims, if you are having a colour that is already creamy, you may not notice the yellowing of oil paint that much (if anything!). So if you want oil paint for trims, I think you could still use it - providing the colour is off white / creamy. My signature is distracting people from my wise posts ... Re: satin/matt/ gloss/flat which paint where? 5Feb 11, 2011 10:24 am nar, I want white really...those 2 are nearly white. so acrylic is fine. Easy to touch up too...dont have to clean the brush in turps!! thanks again, have emailed builder. I asked this question of one of the forum's resident cabinet makers who may/may not wish to identify himself to answer other questions if he sees this, but the rersponse… 3 7731 I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4123 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13907 |
