Browse Forums Finishing Touch 1 Sep 18, 2010 10:57 am I'm painting a timber entry joinery door and have so far done a single coat of oil based multipurpose primer/sealer. The door has routing on it and I'm wanting the finish to be as shmick as possible. How watery are the oil based primers supposed to be? This one doesn't have a consistency anywhere near the thickness of acrylic. How many coats of primer should I be using before applying colour? As it's very thin, I can still see through the primer. Should I be using a brush for the finish coats or just brushing on the routed parts and rolling the flat? People make one happy, not houses? I do not think so. Houses are more to be trusted than people. Elizabeth Aston, Mr. Darcy's Daughters http://www.youtube.com/watch?v=pmDX0tgONFs http://lightndreamy.blogspot.com/ Re: Painting a timber door 2Sep 28, 2010 10:46 pm not sure about your product, but primer/sealer doesnt necessaraly have a 'build' you may have to also use a dedicated undercoat. however you said you wanted a 'schmick' finish so... thouroughly sand your 1st coat and apply a second coat. if it is still transperent ( or your going all out) you will require a undercoat. if your not going to get another product, then sand again and gloss. or.. sand and apply an oilbased undercoat (not quick dry) fill any gaps with quality gapfiller, thouroughly sand all edges(trying not to go back to bare- watch the edges) especially in the router, lightly sand the faces of the door, or go nuts apply a second undercoat lightly sand with 240 grit paper or a sanding sponge.. your door should be as smooth as the proverbial.. Gloss.... i'd use a small foam roller to do the flat bits, even for the undercoat if just to save time.. be carefull to wipe the face clean as you brush each routered bit (even for the undercoat) or you will see the brush marks around the routers. Hope this helps. Rhys. Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15966 920 was enough to get the furniture in. We live in a pretty safe area and it’s great to see people walking to the front door. We’re not too fussed about people… 4 1696 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5068 |
