Browse Forums Finishing Touch 1 Aug 15, 2010 7:57 pm Now that the doors have been hung and the skirting and architraves are in, our house is really taking shape.The doors I have chosen look really impressive. 2.4 high with moulding details, solid mdf. What am I looking to pay for 2 pac doors these days or should I get the painter to paint them hung with high gloss oil. I have approx 20 doors, diff. widths. Re: 2 pac or high gloss internal doors? 2Aug 15, 2010 8:10 pm Two pack would be the most expensive option. You would need to take them to the spray business for them to be prep'd sprayed and baked or whatever it is that they do. High gloss enamel would be able to be done onsite by your painter. You would have to chat with your painter to see how much he would charge. Oil based enamel is the pits to use - better finish then water based but oh so messy when actually using it / cleaning up. Hate the smell and feel of mineral turps to clean up. Some things are worth waiting for. Re: 2 pac or high gloss internal doors? 4Aug 16, 2010 1:28 pm We were originally looking to get 2-pak doors for the kids wardrobes - one set was around 3m wide, and the others were about 1.5m - it was going to cost just under $3K - so went for white glass doors instead - like the ones SuH has on her wardrobes... not sure of the exact cost, but much cheaper Building on the Sunshine Coast - Land settled 22nd July 2009 Building contract finally signed (after much deliberation on our part) 11th November 2009 Building commences 25th January 2010 - small local builder End of June - almost completed fit out 26th July - MOVE IN DAY!!!!!!!!!!!!!! Re: 2 pac or high gloss internal doors? 5Aug 16, 2010 1:32 pm Moogles We were originally looking to get 2-pak doors for the kids wardrobes - one set was around 3m wide, and the others were about 1.5m - it was going to cost just under $3K - so went for white glass doors instead - like the ones SuH has on her wardrobes... not sure of the exact cost, but much cheaper We also wanted 2 pak linen cupboards doors and were quoted $3k....opted for same paint as the walls. Re: 2 pac or high gloss internal doors? 6Sep 30, 2010 3:12 pm McKinnon, find a house painter who has a 'HVLP spray gun' or an 'air assisted spray gun' who will spray your doors on site with enamel, this will provide close to a 2pack type finish, for little more than painting the doors by hand. remember that enamell will yellow if it is plain white. doors sprayed with water based enamel can also look very nice, will not yellow, and are hard wearing, though will not be anywhere near as shiny as 2pack/enamel enamel doors should be just as shiny as 2pack, but you cannot expect a house painter on site to get quite as good a finish as a spray painter in a spray booth. also, if your frames are the same colour as the doors they should be done in the same product, to ensure the age the same. Re: 2 pac or high gloss internal doors? 7Oct 11, 2010 11:30 am After about 10 phone calls I found someone to 2pac for $200 a door. The builder said ok, so they picked them up and guess what, the builder will cover the cost and he said you pay for the custom made front doors. I did the phoning not the builder Re: 2 pac or high gloss internal doors? 8May 23, 2020 4:23 pm McKinnon After about 10 phone calls I found someone to 2pac for $200 a door. The builder said ok, so they picked them up and guess what, the builder will cover the cost and he said you pay for the custom made front doors. I did the phoning not the builder Who did you use please for the spraying? Okay, then the choice is really about the build quality of the door itself which means the brand name. Sorry I can't recommend one or the other so best to rely on comments… 5 3322 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6831 This link might answer your question. I had the same issue and it turned out to be the roller. https://www.sherwin-williams.com/painti ... %20coating. 4 18203 |
