Browse Forums Finishing Touch 1 Dec 08, 2009 1:31 pm Hi all, Just wondering if anyone has any advice on painting internal wooden window frames. They already have paint on them which I will need to sand back, I guess?? Please help! Re: Advice re painting window frames 2Dec 14, 2009 6:25 am Depending on what condition the existing paint work is in, will depend on how much prep work you have to do. 1) Sand back with a medium grade sandpaper 2) Wipe clean 3) Undercoat 4) Topcoat with a full gloss enamel paint. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Advice re painting window frames 3Dec 14, 2009 6:35 am If the paint is in really poor condition, get yourself a detail sander. Hand-sanding is the pits. Our old place had nasty dark brown matt finish paint on all timber trims and I wanted nice cream gloss. It took some work - I had to sand right back to bare timber - but it was worth it. Get a couple of different sized paint brushes too - there are usually a few surfaces of different widths to paint and it's a pain trying to do it all with the one brush. Re: Advice re painting window frames 4Dec 14, 2009 8:36 am Enamel is available in water-based now - much easier to use and clean up Re: Advice re painting window frames 5Dec 14, 2009 8:52 am Dukekamaya Enamel is available in water-based now - much easier to use and clean up Not as good..... Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Advice re painting window frames 6Dec 14, 2009 11:17 am Thanks for the advice everyone... may be tackling this next week... wish me luck! Re: Advice re painting window frames 7Dec 14, 2009 11:43 am Michelle Dukekamaya Enamel is available in water-based now - much easier to use and clean up Not as good..... I know a Master Painter who would disagree. I used it on the skirting in my place, have had no problems at all. It doesn't yellow like oil-based enamel either, it stays a true white Re: Advice re painting window frames 8Dec 16, 2009 6:10 am Dukekamaya Michelle Dukekamaya Enamel is available in water-based now - much easier to use and clean up Not as good..... I know a Master Painter who would disagree. I used it on the skirting in my place, have had no problems at all. It doesn't yellow like oil-based enamel either, it stays a true white Ohhh dear, it’s obvious we don’t know the same painter….shame. I had one tell me it’s no good. Well, you’ve tried it, I haven’t so I’ll be quiet now…….. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Advice re painting window frames 9Dec 16, 2009 6:07 pm Isn't that the saying...... "don't knock it till you've tried it" ? For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 7713 That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 17858 |
