Browse Forums Finishing Touch 1 Sep 14, 2009 4:09 pm Hi all, I have a window by the stairs, 3.1m high x 0.8m wide. My intention is to cover it with a roller blind with some light filtering fabric. However, I was told by a blind company that the maximum height for a roller blind, venetian and roman blind will be 2.4m, some fabric may have up to 3m. But nothing can cover the 3.1 high window. Is this true?? Do I happen to have an unusually large/tall window? What do people use to cover such tall window generally? Any comments is appreciated! Building Clarendon Brighton - Done and moved in Sept 2009 Re: Blinds options for a 3.1m high window 2Sep 14, 2009 8:05 pm I dont understand why they cant turn the roll around and put the 2.4m wide at the 0.8m edge and get you your 3.1m. Can you stand on the stairs and acutally pull down the blind if it is all they way up the top? It seems like a massive window to me, you could get a custom made shutter, which would cost you approx $1000. Re: Blinds options for a 3.1m high window 3Sep 14, 2009 9:47 pm Yes, this is quite a massive window (height-wise). The window can't be opened. Probably best to show by picture Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This window is great for bringing light in. But this needs to be covered for privacy. Building Clarendon Brighton - Done and moved in Sept 2009 Re: Blinds options for a 3.1m high window 4Sep 14, 2009 10:21 pm How about decorative window film ? http://www.handihome.com.au/decorative_window_film.htm http://www.windowfrosting.co.nz/security-window-film.html Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Blinds options for a 3.1m high window 5Sep 15, 2009 8:29 am could you not get a custom made roller blind made to suit? Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Blinds options for a 3.1m high window 6Sep 15, 2009 12:34 pm Southies, thanks for the suggestion. But I would prefer blind over film as I can still pull up the blind while film can't billdsl, I was accent I went to. They are custom making the blinds (I think) and they just say they don't do that. I am not sure if it is just them or maybe other company is more flexible. Building Clarendon Brighton - Done and moved in Sept 2009 Re: Blinds options for a 3.1m high window 7Sep 15, 2009 12:54 pm hmm, these guys allow you to have up to 3m drop, that might do the trick. if you were really worried about it closing at the bottom you could do an outside mount and just do it that extra bit down from the top so it covers the bottom, depends no what you need http://www.justrollerblinds.com.au/# I havent used them but was thinking about it depending on what I can track down locally. They are a lot more flexible than your shops Ive found Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Blinds options for a 3.1m high window 8Sep 25, 2009 12:38 pm if that was me I'd never get around to opening the roller blind anyway, makng that huge lovely window a bit of a waste Are you absolutely opposed to curtains? a sheer one might do the trick. Oh... but perhaps not at night hehe. Is there a particular neighbour's window or something you're looking for the privacy from? Maybe some kind of vertical louvre on the outside? Re: Blinds options for a 3.1m high window 9Feb 28, 2010 9:18 pm i know we can do up to 3.6meters X 2.8 meters with out railroading the fabric, the problem is most places only have a table that can cut up to 3meters. Will you be able to reach the chain from the bottom of the stairs anyway ? Venetians, Verticals, Shutters & Romans will also work. Re: Blinds options for a 3.1m high window 11Mar 01, 2010 11:41 am Accent blinds installed a 3.1m drop roller blind for me there. The thing they were concerned about was the heavy load on the roller. Since the blind will not be rolled up and down often, it was ok and they are happy to install that for me. Building Clarendon Brighton - Done and moved in Sept 2009 Re: Blinds options for a 3.1m high window 12Mar 20, 2010 7:22 am I have a similar window. I'm getting a roller blind...not sure how it'll go but will know in 3 weeks when they come and install it Built Liberty 42 - Handover 26th Feb 2010 forum thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=17243 It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8195 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39288 About a year ago, I embarked on a DIY project to construct an outdoor Pergola, which measures approximately 5.2 meters by 4.0… 0 29555 |
