Browse Forums Finishing Touch 1 Aug 27, 2009 12:33 am I know the difference between acrylic & enamel paints being water or turps cleanup. My question is - with a semi-gloss which would have the higher sheen level? Does the preparation/undercoats & number of them underneath affect the gloss level? Appreciate any thoughts. Re: Paint gloss level 2Aug 27, 2009 1:13 am Semi gloss against what? Gloss is how the paint is made they add fillers to reduce the sheen Onc_artisan Where you are coming from is where you are going to... Re: Paint gloss level 3Aug 27, 2009 9:44 pm Matt /Low Sheen/Semi Gloss (satin)/Full Gloss There the common Sheen levels ,different paint manufacturers in gneneral use the same sheen "names" or references however the sheen level may slightly be different. Yes undercoats effect the level of the sheen. Matt & Low sheen are common for walls. Semi & Full gloss common on woodwork/doors. There is also Flat which is no sheen at all or very little , commonly used for ceilings but also available for walls. Re: Paint gloss level 5Aug 28, 2009 11:06 pm Thanks Swarvy, so semi-gloss enamel would be slighty more shiney, which is what I thought. My painter is doing 2 undercoats and only 1 of semi-gloss enamel and I am thinking its not as shiney as should be. Perhaps I need 2 coats semi-gloss. Re: Paint gloss level 6Aug 30, 2009 3:31 pm supasquirrel Thanks Swarvy, so semi-gloss enamel would be slighty more shiney, which is what I thought. My painter is doing 2 undercoats and only 1 of semi-gloss enamel and I am thinking its not as shiney as should be. Perhaps I need 2 coats semi-gloss. On what? The timber work? I recommend full gloss. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 This link might answer your question. I had the same issue and it turned out to be the roller. https://www.sherwin-williams.com/painti ... %20coating. 4 18150 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 |
