Browse Forums Finishing Touch Re: Tips for Painting a New House 21Jun 20, 2007 8:47 pm Yes they will add more of the lighter tint to the paint to make it the colour you want.
Probably will only need a drop or 2. I’ll take a look at your post. In all honesty…..do the wall any colour you like. It’s you that has to live with it. I look at things differently, I have too, I’m a professional in colour. My whole house is matching colour wise, but how would it look to my clients if it wasn’t? It’s your wall and your home do what makes YOU happy, as long as you like it, that’s all that matters. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Tips for Painting a New House 22Jul 25, 2007 10:52 am Why do you want to use enamel undercoat? You really only need it if you have to seal stains, water leaks and mould. Otherwise use water based undercoat – it’s much easier to apply, dries quickly and smells much less. Make sure it dried properly before you put final coat on top of it. Otherwise your paint will develop a mesh of little cracks.
About mould staff… They have a liquid call Mould Killer – just add it to you paint as per instruction. Smells badly, but it really works. We use it a lot! You would need to treat the surface with Mould Killer spray before painting for the best results. Most of paint shops will have they in stock. Also – Barloworld had has those really good antibacterial paints which basically have premised antibacterial ingredient already. The price is close to normal premium quality paints. Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7231 Thank you so much. This has been very helpful. We definitely wish to settle and get these people out of our life. They are trying to charge us interest on late… 7 14278 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5038 |
