Browse Forums Finishing Touch 1 Apr 21, 2009 9:22 pm I have a dark stained suite almost a chocolate wenge colour but the sun seems to have lightened it so I want to stain it dark again as I am having timber blinds in espresso colour in the new house. I bought a tin of walnut stain from bunnings and the guy said if I put that on top it will go dark as its quite dark already. He gave me some stuff to sand it back a bit but it seems to scratch (he said it wouldnt). Can I just put this stain/varnish all in one stuff straight on without rubbing back? Wouldnt it be the same as doing 2 coats but a bit longer apart????? DH cant see anything wrong with the suite and doesnt understand why I want to change it. So I am scared in case I stuff it up, I will never hear the last of it then I really dont want to sand I just want to go straight to the fun bits I was even thinking of getting a new suite and putting this one in the guest room, but that is an expensive excercise at this stage of building a new house Know where your going in life............... you may already be there Re: Restaining a bedroom suite 2Apr 23, 2009 9:03 am Hi Taffy, i believe you will have to sand it back Yep its boring and tedious but if you put the stain right over the top i am guessing it will just run off. Most timber furniture will have a coating of something over the stain they used so that the finish is preserved. You will need to "rough up" the surface so that the new stain you are applying has something to grip on to. In most cases a fine grit sandpaper will do. Good luck but in any which way it will be a big job and something you really want to do properly. Hope this helps Re: Restaining a bedroom suite 3Apr 23, 2009 9:13 am FlissFloss is right. You will have to sand to cut through the laquer/varnish to get the stain into the wood. It will be a big job and you would be better to take the bed apart and do it outside. Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10478 Hi, I'm planning to build a new house and wanted to get some feedback on the different window designs for a master bedroom. Our bedroom is north facing and the bed will… 0 4559 1 15758 |
