Browse Forums Finishing Touch 1 Feb 10, 2009 10:46 pm Im painting feature walls and tossing up between Dulux 101 flat and designer silk. Not sure if I should use a matt finish or low sheen for feature walls? The paint on the walls are currently a matt finish.
Also can anyone recommend a good place to buy dulux paints that mixes the colours well and are fairly low priced in Sydney city or inner suburbs?? [/b] Re: Dulux wash & wear 101 or Dulux Designer silk paint? 2Feb 13, 2009 4:12 pm We just went through this same thing only 2 weeks ago.
We wanted 4 litres of the designer silk paint in Sultry Glance (almost like brick red), only to find out the red base only comes in a 2 liter can, that meant forking out nearly $200 for 4lt ! Instead we got the Sultry Glance tint in the 101 Wash and wear low sheen for half the price, same color but the finish isn't quite as smooth as the designer silk but that suits us fine, we aren't overly fussy. silk 3Feb 13, 2009 8:03 pm WE did our feature wall in 'silk'. Yes it's expensive but we were only doing one wall. It goes on better, looks better and is a great paint BUT, yes it's expensive. We would not have been able afford to use it for a whole room. www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4716 2 833 Your build is relatively simple, I believe your job can be easily done by a good building designer, you really do not need to pay for the architect. Remember, architect's… 3 10995 |
