Browse Forums Finishing Touch 1 Jan 30, 2009 9:52 am Hi guys,
I have just recently painted all the render on my house. I also have some blue board around my deck that I would like to make look like it’s rendered. Now I know there are plenty of paints out their to make blue board look like render. But after painting the house we were left over with enough paint to paint the blue board. Is there any sort of additive that you can add to normal paint to give the rendered effect on the blue board? Thanks in advance for your help. Re: Render Paint 2Jan 30, 2009 8:10 pm There are a number of products out there that mimic the render look.... Just look at the Dulux website....
Also might be worthwhile checking with your renderer, how long you should leave the render before painting for best results... Typically you can get a bleed through if done too early.... Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Hi Alex, Thanks for the reply again. I had a chat with the builder, he said he will use primer, then hydrotec which comes with colour and sealer as well. A Renderer I… 12 18098 I am looking for someone who might have tackled a similar issue as me. I have a few rendered interior walls, the surface condition is hardly flat. I can see all the bumps… 0 7967 Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,… 5 6921 |
