Browse Forums Finishing Touch 1 Oct 04, 2015 1:10 pm Hi all, can anyone suggest a suitable product please. I've built a floating tread staircase & have been using POR15 2 pak for the steel work & structural beams etc. I live in Cooktown & the heat & humidity have made application a nightmare - 4 times I've started from scratch to get a good / acceptable finish. Anyhow stringer is done & looking ok but the steelwork for the balustrade support I ended up sanding back again & have used White Knight Squirts multi purpose enamel to do these bits of the structure. The finish is good but I want to use a product that will finish this so it looks similar to the high gloss of the black POR 15. I would prefer to apply with brush or roller rather than spray & due to my bad experience of 2 pak would rather a single type product. So looking for a clear high gloss top coat that can go over enamel Thanks in advance for any help. Cheers, Chris Re: High Gloss clear top coat to go over enamel paint 2Oct 07, 2015 8:08 pm Dulux professional polyurethane clear gloss. Available at dulux trade centre outlet only. Apply with mohair trim roller Re: High Gloss clear top coat to go over enamel paint 3Oct 07, 2015 8:12 pm available in 4 litre only. This link might answer your question. I had the same issue and it turned out to be the roller. https://www.sherwin-williams.com/painti ... %20coating. 4 18312 The yellowing mainly occurs to white or very light colours. 1 3035 |
