Browse Forums Real Estate Home Seller: Advice on Real Estate Agents. 7Feb 04, 2016 1:39 am Building a Porter Davis Livingstone 23 in Mayfield, Cranbourne East | Our thread 18/05/15 - Contract Signed 24/12/15 - Land Settlement 30/1/16 - Slab poured 9/06/16 - Handover Re: Home Seller: Advice on Real Estate Agents. 10Jul 14, 2016 7:21 am Buying and selling any real estate is alot of negotiation. As you can only talk to the realtor, find someone with a personality and skillset that you can WORK WITH. In the above, the 'senior' realtor who was talking 'at you', well he'll likely do the same during buyer negotiations with you. Above again, badly worded card (likely written by a junior to all 'warm leads'), negotiations would likely be email and 3rd parties. And if hes busy you'll probably go thru his PA. There are alot of assumptions here made, but all you have to go on is how they come to you. If you can WORK WITH a personality and they aren't completely hopeless (as above bad photo work of house) then you can only TRY. As long as your property has decent pics (touched up sky and grass, usually evening with lights on for the glow) and realtor advertisers on RE.com and Domain, has a sign board on house that is large and decent (pics too?) and holds open houses, then you'll find 95% of active buyers for your home. Hopefully they answer the phone and email enquiries that come in and followup ALL interest from open houses. Good luck Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15670 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 45706 |
