Browse Forums Real Estate 1 Jul 22, 2013 11:35 pm As I get nearer to buying a house, was wondering if anyone can enlighten me as to how I go about it. That is, when I find something I like, do I make an offer then get an inspection, or do I get an inspection then make an offer? I will be buying an older place so an inspection will of course be necessary to know if the house is ok or how much it will cost me to make it ok. It's been a while since I went through the buying process. Would appreciate any hints or tips. Cheers Re: Buying a property - been a while 2Jul 23, 2013 12:00 am You can put a special condition on the offer along the lines of this offer is subject to a satisfactory building inspection paid by the purchaser. The Real estate agent should be able to write the condition on the offer. This gives you a way out if you are unhappy with the results, also you could re-negotiate if there are any repairs required etc. Hope this helps. Re: Buying a property - been a while 3Jul 23, 2013 12:03 am Generally you get pre approval from the financier, then you go and look at places and put an offer on the one you like, you write on it "subject to finance chosen by the purchaser" and also "subject to structural and termite inspections, satisfactory to the purchaser". If they accept, you get the inspections and go for formal finance approval. If you cannot get finance through your financier, you can go elsewhere, or cancel. They cannot make you get it through Joe knuckles crack your skull mortgages. If you don't like the inspection reports, you can pull out without penalty also... .at least that is what we do. ______________________________________________________________________ Signed up Jan 2013........Almost done! My thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=65763 Re: Buying a property - been a while 4Jul 23, 2013 10:33 am Thanks for the replies. Have noted down the wording suggested. Re: Buying a property - been a while 5Jul 23, 2013 5:09 pm The process varies depending what state you are in. But it is essential to have pre approval for the loan so you know your limit. In NSW you have a cooling off period to organise building and pest etc. If you are Sydney you'd have Buckleys chance of getting subject to finance clauses put in. Everything is being snapped up. They'll just go for the person willing to sign unconditional. Re: Buying a property - been a while 6Oct 26, 2013 1:21 pm Iceprincess-Li You can put a special condition on the offer along the lines of this offer is subject to a satisfactory building inspection paid by the purchaser. The Real estate agent should be able to write the condition on the offer. This gives you a way out if you are unhappy with the results, also you could re-negotiate if there are any repairs required etc. Hope this helps. This is what we did the first time we purchase a house, me and the seller agreed on our condition then negotiate in the end for any repairs. Hello everyone Please advice me how can I install mesh security window or we cab say mesh flyscreen inside while the pvc plantation shutters are already installed? Is… 0 11670 Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72389 You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18175 |
