I have some very stupid questions:
What is a clad home? I guess that it is different from weatherboard. Is it the plastic stuff you put on top of the weatherboard?
If a house is called "brick veneer", is the inside always a steel frame or might it be a timber frame as well? Are the inside walls then timber frame? Is this a sound construction?
If you see battens on the outside wall, does that always mean that it is a fibro house?
