Browse Forums Real Estate Re: Buying Land 10Sep 04, 2009 1:37 pm Im going to have a look at two blocks tomorrow, both are new release by a large developers. I want to place a HOLD the first block, then quickly check out the other block as well. Question is, what are the normal procedures when placing a block on hold? I assume there would be a small deposit, but is it normally refundable if you dont end up purchasing it? How long can you hold a block for generally? 12 March 2010 - Land titles received 3 April 2010 - Signed building contract 14 April 2010 - Prestart 28 April 2010 - Loan approved 30 June 2010 - Slab completed 27 August 2010 - Brickwork completed 22 September 2010 - Roofing completed 30 September 2010 - Internal walls plastered 12 October 2010 - Lock Up 19 November 2010 - PCI 26 November 2010 - Handover 29 December 2010 - Moved In https://forum.homeone.com.au/viewtopic.php?f=31&t=32584 Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried… 0 6443 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24864 13 6632 |
