Browse Forums General Discussion 1 Aug 10, 2020 8:09 pm Hi, I am trying to find an exterior low sheen paint to match Colorbond Trimdek Surfmist matt. I will be painting on horizontal hardiplank and was advised that I should use half strength? Any advice or suggestions are most welcome. Thank you DIY, Home Maintenance & Repair Maybe stick with some of the cool whites like Lexicon or White on White. 1 2034 Hi, Should I match the stringers and treads to the exterior walls and trim? I have no deck or verandah, so you step out of the house directly onto the stairs. Any… 0 531 I painted Surfmist onto separate boards and labelled on the back. I also chose Basalt as a trim and found after two coats that this is an exact match to Colorbond Basalt.… 1 731 |
