Browse Forums General Discussion 1 Aug 06, 2020 9:04 am Those of you with the 3/4-in-1 bathroom exhaust fan units, do you find them to be efficient(especially with steam extraction)? If yes, what model do you have? Our standard inclusion is an externally ducted exhaust fan over the shower but I was advised to get one of these units instead. Thoughts? Re: 3 in 1 Exhaust fans in bathrooms vs standard exhaust 2Aug 06, 2020 10:30 am We have HPM 3 in 1's in both bathrooms. 1. Do they efficiently extract steam? Yes most certainly. 2. Are the heat lamps effective? No, not really. If you have the heat lamps on without the fan then you'll get the effect but that's not recommended so any heat generated by the lamps generally goes straight out through the exhaust. We did initially use the heat lamps to warm the bathroom without the fan being on - until I noticed that the plastic close to the lamps was scorching and melting. We now have a wall mounted ceramic heater fitted. 3. Is the single light globe in the middle of the 3 in 1 sufficient for bathroom lighting? No, you'll need additional lighting above your vanity. Re: 3 in 1 Exhaust fans in bathrooms vs standard exhaust 3Aug 06, 2020 10:36 am Althom We have HPM 3 in 1's in both bathrooms. 1. Do they efficiently extract steam? Yes most certainly. 2. Are the heat lamps effective? No, not really. If you have the heat lamps on without the fan then you'll get the effect but that's not recommended so any heat generated by the lamps generally goes straight out through the exhaust. We did initially use the heat lamps to warm the bathroom without the fan being on - until I noticed that the plastic close to the lamps was scorching and melting. We now have a wall mounted ceramic heater fitted. 3. Is the single light globe in the middle of the 3 in 1 sufficient for bathroom lighting? No, you'll need additional lighting above your vanity. Thank you so much. In that case, I am probably better off with the standard exhaust and having downlights. I hadn't thought much about heating but I am hoping its something I can address later if needed. Re: 3 in 1 Exhaust fans in bathrooms vs standard exhaust 4Aug 06, 2020 10:41 am Althom 3. Is the single light globe in the middle of the 3 in 1 sufficient for bathroom lighting? No, you'll need additional lighting above your vanity. This. The light is basically useless on ours (and the one in our old house) - you need the heat lamps on to see anything! My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is… 0 5124 There may be answers here but can't find anything. I have a closed in veranda, four windows. North facing, just had sunblock blinds installed. A bit cooler (actually… 0 2978 What we have done in a few theatres ( including my own) is run 2 layers of 13mm gyprock, but sounds insulation especially for the bass is really tricky as a lot of that… 4 2569 |
