Browse Forums General Discussion 1 Aug 02, 2020 11:48 pm Hi, I have planted a few Yucca Aloifolia plants in front of my house its nearly 2.5 years old. One of my neighbors and friend suggested that these plants can damage the Foundation Wall and create big problem in the structure. I am attaching the pictures. Can anyone suggest? Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Yucca Aloifolia - Plant around House Foundation 2Aug 03, 2020 7:45 pm Small ones no, but when they get bigger their roots can do a lot of damage. They can have a disproportionate root system for the tree size. I'd look at transplanting yours to somewhere else on your property and choosing a better suited variety for that location. Stewie Re: Yucca Aloifolia - Plant around House Foundation 4Aug 12, 2020 9:50 pm Drive around and look at a few mature versions. Then you will move them. You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7034 Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 4683 0 4711 |
