Browse Forums General Discussion 1 Jul 29, 2020 9:36 am A horizontal beam in my backyard fence has rotted and broken and needs replacing. The problem is that if I buy a beam of the correct length I will not be able to slot it into both vertical posts as it will be too long. Is there a trick to this? At the moment my plan is to buy a beam of the correct length then cut a bit off each end (as little as possible) so that I can slot it all the way in at one end then slot it in at the other end and finally move it across so that it is secure at both ends. Any other suggestions? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I have an investment property and tenants moved out recently. However the Property manager noticed one of the floor tiles is broken and the kitchen Island countertop is… 0 15510 11 2522 Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 13791 |
