Browse Forums General Discussion 1 Jul 28, 2020 7:56 am Our driveway is done, not sure how I feel about the angle coming from the right..does it look right? I would prefer the angle to come across lower, doesn't seem like much room to park.. Thoughts? Would you question it.? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Driveway 2Jul 28, 2020 9:27 am Yes, personally I would have cut the corner more or even done a straight line from the stairs to where it meets the kerb (need room for the basketball ring as well!). Didn't you discuss it with the concreter before they did it or at least mark it out or draw a diagram as to how you how you wanted it? If you just left it up to them they are going to do it so as to use as little concrete as possible Re: Driveway 3Aug 09, 2020 9:49 pm amy1977 Our driveway is done, not sure how I feel about the angle coming from the right..does it look right? I would prefer the angle to come across lower, doesn't seem like much room to park.. Thoughts? Would you question it.? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ hi, can I ask how wide is your driveway crossover? just curious to see with the driveway that will be for my build. To my understanding early saw cuts are to control shrinkage cracks, so doing them now would be pointless. Control joints may reduce ugly cracking during periods of soil… 3 9858 Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 10939 |
