Browse Forums General Discussion Re: Plan feedback please 5Jul 28, 2020 2:02 pm Not a bad layout but your draftie needs to go back to school. God those leader lines. 1500wide entry hall is a massive waste in my opinion. Give more to the guest room areas. (My niece did the same thing and her bedrooms suffered. Tiny 3m beds, now she tells me I should of listened to you) Your panel lift garage door is clashing with the storage area to the left. This may be an issue as the garage door, (when retracted) is lower than the ceiling. If you have storage shelves to the left you wont be able to put much on the top shelf, adjacent to the garage door. Most of your window and sliding door openings are not centered. (living room for example) Get rid of the winders on your stairs, you have plenty of room on level 2 for a proper stair with a mid landing. Winders won't be a good idea when you're old or have any elderly come over. You need to locate those 2 manholes ( the black circles) and run a string line between them They may be covered in dirt or plants but do some hunting and you will… 1 5226 My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is… 0 12746 |
