Browse Forums General Discussion 1 Jul 26, 2020 7:19 pm Gday I’m looking at buying a house. I am going to get a building report from a licenced person but just wondering if anyone here can help me. I am wondering if the roof extension looks legit or not they have raised it and extended it out. Just looks a bit suss with ply holding bracing and not much support. Thanks heaps in advance. Cheers Mitch Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Extended/raised roof legit 3Jul 27, 2020 1:17 pm Stewie D That does look a bit d0dgy. Further down those newer rafters, is there any support over their lengths like an under-purlin? Stewie Gday mate cheers heaps for the reply. No as far as I can see there isn’t anything just that bit of ply at each end. On one side roof is probably raised about 500 the other only 300. So if ornate had and under purloin you think it’d be sweet. Cheers again Re: Extended/raised roof legit 5Jul 27, 2020 8:03 pm Pulse definitely not allowed under timber framing standards, might work but definitely an illegal extension, on the plus side the original trusses look intact Gday mate cheers for your help. Would it just require some more bracing for it to be legal? All the new roof is all ready on does it have to be fully pulled down or just braced? Cheers mitch Re: Extended/raised roof legit 7Jul 29, 2020 8:37 am Hi Pricey102 That Extension is non compliant consult with your Council Building Surveyor They will require you to have the trusses certified by a Structural Engineer ...Goodluck with that hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs yep, clearly mark where the infloor heating pipes are before drilling or nailing 1 6068 2 9451 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28326 |
