Could someone please tell me where I would find guidelines on acceptable levels of edge heave?
I am trying to work out at which point slab heave exceeds acceptable levels.
Thanks.
Browse Forums General Discussion Re: Edge Heave 2Jul 19, 2020 11:45 pm Hi. Lisa06 i think you will find it on tbe AS 2870 as well i think if am not wrong deepending on your soil classification as to how much movement you should have as standard. But also on the 2015 VBA standards and tolerance. Have a read of that its free online. Re: Edge Heave 3Jul 20, 2020 4:40 pm Mauromario Hi. Lisa06 i think you will find it on tbe AS 2870 as well i think if am not wrong deepending on your soil classification as to how much movement you should have as standard. But also on the 2015 VBA standards and tolerance. Have a read of that its free online. Thank you -I will have a look. Re: Edge Heave 4Oct 05, 2020 5:05 pm I've noticed lately a lot of talk about slab heave but also I've been told more volume builder are putting piers in New homes, I'll spoil this a little if you have slab heave piers will not help or do anything nothing will stop heave regardless if you have piers, also unless the piers are actually have steel rods tied into the waffle slab to hold it down from heaving upwards. Piers are ok only if the soil is sinking shrinking or to much fill not compacted and collapsing under the weight of the house and also to how deep the piers are how far apart. I've just had my house underpinned by the builder I am sure some people on tnis forum know my story, well my piers are 3.8 metres deep and 1.2 metres a part but have been tied into the slab by engineering disign, I was taking photos of every hole putting take measure inside to make sure they achieved the right depth and what really surprised me was the first 2.8 metres it was all fill top soil we didn't hit clay till 3.5 metres then went another 300mm so even at 2.8 metres there was no clay or soilid ground it was just fill. I had to make sure these idiots put a 50mm base of concrete first let that set than continue with the rest of the poring of concrete and leaving room for hydrolic jacks to Jack the slab back up to a level before hand over was done in 2010. My argument here is even if you have a vcat order in your favor these builder will still try and cut corners I feel sorry for people that don't know and leave it just to the vcat orders but not actually check that the builder is doing the right thing,, so far they have tried to take short cuts at every turn it's driving me nuts that these builders will continue to take short cuts even with vcat orders in place, you got to eyes in the back of your head and stand your ground and really have a go at them or stop the work send everyone home and tell the builder I am reinstating the vcat orders it's the only thing they understand is threat. Thats my piece my opinion. Re: Edge Heave 5Oct 05, 2020 6:12 pm Mauromario It seems that on a surface like that you could be better off with just one well stiffened raft e.g. 250 mm thick with 2 layers of 10 mm or even 12 mm reinforcement forming 10x10 cm cells. It would just float over whatever happens down below. Re: Edge Heave 6Oct 05, 2020 6:28 pm Your so right if ever I build again it will be the old raft slab, i was talking to some concreters and they tell me not much difference between raft and waffle it's just a way for builders to cash in extra with more problems down the road, who ever allowed waffle to be used here in Australia should not be in goverment. Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12878 |
