Browse Forums General Discussion Re: windows out of plumb by 5mm 5Jul 15, 2020 9:26 am I've just seen your other posts and see you are past when they would have done frame straightening etc. Has the builder shown you proof its in tolerance? I agree that you easily need 3-4 hours for a PCI even if you've been watching the build closely along the way. Re: windows out of plumb by 5mm 6Jul 15, 2020 11:02 am Jo11 we had issue with issue with window out of plumb by 5mm, You need to have this thread moved to the Windows & Doors sub forum. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: windows out of plumb by 5mm 7Jul 15, 2020 12:28 pm hi thanks for letting me know. i am new to the forum, still bit confused with where to post questions. by the way, how do i move the question to the right forum? i can't seem to find way to do that, thanks Re: windows out of plumb by 5mm 8Jul 15, 2020 12:32 pm How do you know they are out of plumb? Do sashes and panels operate freely? "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: windows out of plumb by 5mm 9Jul 15, 2020 12:48 pm luxbuild I've just seen your other posts and see you are past when they would have done frame straightening etc. Has the builder shown you proof its in tolerance? I agree that you easily need 3-4 hours for a PCI even if you've been watching the build closely along the way. yes i am now almost reaching the PCI inspection. we also engaged our own inspector for the frames and pre-lining stage, but somehow, he missed most of the windows. no, the builder just told us that they won't fix the window 2.5m wide which is the box window as it will be major work, other windows in Ensuites, they just said 5mm wouldn't be even noticeable. So I guess i will wait until we get our own inspector in and ask. I am planning to walk my PCI first, definitely take 3-4 hours or more as i will be taking my times slowly and testing everything i could. when should I get my inspector to come in, before my PCI or after? I am thinking for them to come after my PCI, then the builder rectified my list, after that my inspector can come in, but site supervisor said not enough time to handover. what do you think? thanks by the way, I am still looking for good inspector, can't seem to find yet. we contacted housepect they charged $984, expensive for us, not sure about the quality of their report and how detailed they are. Re: windows out of plumb by 5mm 10Jul 15, 2020 12:56 pm ECOECO How do you know they are out of plumb? Do sashes and panels operate freely? hi ECOECO, we measured them. we did that from the outside and inside window sills. so we measured right and left corners and middle, then we worked out the differences. at this stage, we don't have a chance to close and open all windows, but we noticed that the track sills for the panels to open and close is pretty dirty. so I think I will have to check them at my PCI walk after they cleaned the windows. Re: windows out of plumb by 5mm 11Jul 15, 2020 1:04 pm Inspection should be well before PCI. If major defects are found you can dispute practical completion has been reached. Any defects identified at PCI should just be cosmetic items like paint blemishes and can be fixed quickly later before handover. Things you can see for yourself. I used Houspect. Their report was detailed. I accompanied them on the inspection and ensured as much as possible was checked. I learnt from the inspector and the NSDFT guide, then spent time onsite later carefully inspecting everything. Missed one small window not square, however! Re: windows out of plumb by 5mm 12Jul 15, 2020 2:10 pm Jo11 by the way, how do i move the question to the right forum? i can't seem to find way to do that, thanks You could report your own post and ask for it to be moved but ECOECO, the resident windows expert, has now seen this thread and posted replies. Probably still worthwhile asking for a transfer later to assist others who later search the Windows & Doors sub forum looking for a topic of importance to them. This thread has a good descriptive title. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. 4 14257 Unless there is something in special conditions the builder does not have to give you timeline. If your demolition contractor has not removed Asbestos and it was found… 12 28775 Thanks for the informative response! I'll feed that back to the site supervisor. 2 4102 |
