Browse Forums General Discussion 1 Jul 13, 2020 12:07 am Looks like I will be in a fight with my builder over cracking/movement of slab. The crackings started within a month of the handover of the house and kept re-appearing. It's only a one year old property. The builder has been sending painters everytime to 'fix' it. I am in disagreement with the builder about the cause of the problem too. I am looking for an inspector/advocate who would give me a comprehensive report on all the faults of the building and help me with my fight against the builder and if I need to go to VCAT. Please recommend me a building inspector/advocate who meets the above criteria. Thanks in advance. Re: Building Inspector with dispute and VCAT experience 2Jul 13, 2020 6:22 am Original thread: viewtopic.php?f=31&t=99308&p=1874976#p1874976 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Building Inspector with dispute and VCAT experience 3Jul 14, 2020 7:56 am Hi Willp You will need a current geotech and engineering report There is also a number of things that you should have done and will need to do 1. Have you taken photos of your Siteworks and slab construction during the build? 2 .Do you have a compaction, slab and footings inspection report? 3. Is your brickwork cracking Checking Cracks Above Lintels Using Boschlasers 4. You will also need to Tabulate movements over a period and time, ie check sagging, hogging, twisting,etc these will relate to the cracking patterns in 3 above your independent engineer will analyse your data 5.6.7 Post back and let me know how it's going as it also helps others Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs I would send it to the certifier who is technically your representative and working on your behalf not the builder's 1 2264 yes it does, you've just not understood it. theres a difference. 4 5322 Carlisle use to sneak a water resistant "Performance Solution" into their contracts. Have you checked your contract for same? 4 10027 |
