Browse Forums General Discussion Re: Neighbours hot water solar panel 10Nov 16, 2020 12:07 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Neighbours hot water solar panel 12Dec 16, 2020 9:28 am kasador I think you should consult a specialist if this solar panel installation doesn't violate the rules. And if you find out that they don't have the right to do this, then, of course, you have every right to complain and force them to redo the construction for your safety. Yeah that will work. "Specialist" knocks on neighbours door and tells them "The people next door want me to inspect your solar cell installation". Neighbour says "Get off my property" "Specialist comes back and gives the complainee a $500 bill and walks away. LOL. Re: Neighbours hot water solar panel 13Dec 16, 2020 11:15 am kasador I think you should consult a specialist if this solar panel installation doesn't violate the rules. And if you find out that they don't have the right to do this, then, of course, you have every right to complain and force them to redo the construction for your safety. LMAO Re: Neighbours hot water solar panel 14Dec 16, 2020 10:51 pm This thread is a magnet. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Neighbours hot water solar panel 15Dec 17, 2020 4:50 pm LOL, kasador comes back and edits in the same Thai SPAM that basicman did. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Neighbours hot water solar panel 16Dec 17, 2020 5:09 pm kasador I think you should consult a specialist if this solar panel installation doesn't violate the rules. And if you find out that they don't have the right to do this, then, of course, you have every right to complain and force them to redo the construction for your safety. As for me, I don't understand anything about installing solar panels, so I invited experts to install special lightweight solar samui panels. So, I am sure that they did everything right and my installation doesn't interfere with the neighbors. Anyway if we have any problems, we try to solve them peacefully, cause I am convinced that you need to find a common language with your neighbors otherwise life won't be sweet. LMFAO Nice plug under the lie of I am here to help from Thailand lol! This thread is gold. Re: Neighbours hot water solar panel 17Dec 17, 2020 5:28 pm Crumbs, maybe the Mods should just remove the whole thread. It seems to have run it's course and is now a spam magnet. I must say, I haven't seen the technique of posting and then coming back later to ad the spam link. That takes commitment. The funny thing is, the OP was complaining about solar HWS not solar PV panels. I suppose you don't let those small details get in the way of your spam. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Neighbours hot water solar panel 18Dec 17, 2020 9:56 pm chippy The funny thing is, the OP was complaining about solar HWS not solar PV panels. I suppose you don't let those small details get in the way of your spam. Particularly when they don't know what they are talking about. I'm told that a lot of internet spammers are SEO geeks who seek out large reputable websites like HomeOne as back links. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14052 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20231 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
