Browse Forums General Discussion 1 Jul 09, 2020 10:10 pm This might be a bit out there, but just floating some ideas.... We need a bigger house, we like our location though, we’re on 720sqm block.... is it doable ( if the right person is found) to split our block build us our house and keep the other bit of land for themselves? Re: Free land in exchange for house 2Jul 09, 2020 11:04 pm Subdivision. Yes, it's possible in some areas. In other areas, no it's not. So you'd have to ask your council. But usually the block would have to be a fair bit larger than 720sqm. You may just squeeze in with a large enough block if you're in a zoned area which allows smaller blocks. It also depends on the layout of your block. If you have a wide frontage you could divide the block to form 2 smaller blocks with street frontages. If your block is narrower you may have to subdivide with a battleaxe at the back. In this case much of the land would be wasted on a driveway. 0 4987 13 6634 Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried… 0 6448 |
