Browse Forums General Discussion 1 Jul 03, 2020 6:11 pm Hi all, Coming to the end of a new build and thanks to the recent rain we’ve noticed the driveway doesnt drain properly (see first image). Spoke to builder and their ‘quick fix’ was to cut the concrete slab into four so that the water drains down the very thin cracks (it doesn’t, or if it does, it takes hours). After much back and forth the builders’ new solution is to pour concrete over the top (see second image). Fix-up is not complete but I’m assuming they’ll then buff/polish the fresh concrete and paint to match the driveway colour. We’re worried layering concrete will crack over time. Is this the case? I believe driveway has 7yrs warranty. Should we argue that we want the whole thing re-done? BeforeLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Builders’ solution (not finished)Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Until you find the cause of the flooding you need to take action to mitigate potential damage to your home. Get automatic float pump and dig a pit then connect to power… 2 4864 The bottom of the downpipe has been taped (see the black tape) to seal the necessary gap between the downpipe and the adaptor that would normally prevent the downpipe… 3 9316 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17573 |
