Browse Forums General Discussion 1 Jun 21, 2020 5:26 pm Hi - after some suggestions on what to do next, if anything? We're looking to render our 4-5-year-old home and noticed a month or so ago, that the corner brick on the corner of the garage has moved a couple of mm. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ There are no noticeable cracks on the interior or exterior of the area that has moved. We had bricks hydrochloric water pressure cleaned approx 6 months ago, other than that nothing has changed. There are no cracks anywhere else around the exterior, some small movements in cornice at the other end of the house. Thanks and thoughts? Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20617 Are they stumps or screw piles ? How much fill is there, is the site a class "P" ? A "H2" site is not supposed to have stumps it is supposed to have grid beams according… 1 6955 House movement is always a potential problem and there is a cause. Yes you should have it inspected by a competent and experienced building consultant 2 7058 |
