Browse Forums General Discussion 1 Jun 15, 2020 4:53 pm We've recently taken possession of our new build and are currently living through the maintenance period. We are looking at installing some wireless cameras (to supplement the existing camera blind spots), but the house is largely comprised of exsulite EPS. Now I realise you can't really attach anything heavy to the exsulite, but would something like an Arlo camera be OK to attach? Or would even that be too much? Canberra knockdown rebuild https://the35thweek.blogspot.com Re: Attaching a security camera to exsulite wall 2Jun 15, 2020 6:26 pm That will be no problem. You can get wall mates for poly board from your local hardware and they have different load bearings. here is a site you can get them from https://www.thefastenerfactory.com.au/screws-fixings/plaster-fixings/render-fixings/fid50-foam-render-insulation-fixing-50pc good luck Registered Building Practitioner DB-U 47858 CB-L 41119 email: segalandcoinfo@gmail.com https://sites.google.com/view/segalandco/home?authuser=0 Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5860 which 1) PoE based video intercom is best for two storey home. I am looking with two monitor, one in GF and another FF so someone in home can… 0 24956 DIY, Home Maintenance & Repair Follow up question - any ideas on how to set up a portable air conditioner through this kind of window? 1 6236 |
