Browse Forums General Discussion 1 Jun 15, 2020 5:53 pm We've recently taken possession of our new build and are currently living through the maintenance period. We are looking at installing some wireless cameras (to supplement the existing camera blind spots), but the house is largely comprised of exsulite EPS. Now I realise you can't really attach anything heavy to the exsulite, but would something like an Arlo camera be OK to attach? Or would even that be too much? Canberra knockdown rebuild https://the35thweek.blogspot.com Re: Attaching a security camera to exsulite wall 2Jun 15, 2020 7:26 pm That will be no problem. You can get wall mates for poly board from your local hardware and they have different load bearings. here is a site you can get them from https://www.thefastenerfactory.com.au/screws-fixings/plaster-fixings/render-fixings/fid50-foam-render-insulation-fixing-50pc good luck Registered Building Practitioner DB-U 47858 CB-L 41119 email: segalandcoinfo@gmail.com https://sites.google.com/view/segalandco/home?authuser=0 I am thinking of a POE system with 8 cameras for my single storey house. Any idea where best to mount each camera? I think 2 front, 2 rear, 2 on left side of house and 2… 0 2374 ![]() Hi everyone, I am planning to build a pergola in our garden and want to fix the ribbon plate to the existing metal fascia of our alfresco. How do I locate the rafters of… 0 857 DIY, Home Maintenance & Repair If you cast them in I'd suggest welding them to a plate and casting the entire plate in with the threads off that. If you chemset get a spanking new quad tip drill bit… 8 1940 ![]() |
