Browse Forums General Discussion Re: Staircase finish 2Jun 05, 2020 1:34 am Lazy carpentry. Even the other cut looks average. Ask supervisor how they will rectify, or have a look at your drawings and see if it was detailed. Re: Staircase finish 4Jun 05, 2020 9:02 am It doesn’t necessarily need to be flush, but it shouldnt look like that. Re: Staircase finish 5Jun 11, 2020 8:09 am Wrong! The stringer for the staircase would be 30-40mm in thickness for strength whereas the skirting is only 18mm. Nothing they can do about it although the installer could have run the stringer through higher and made it look like the skirting runs into it. Stewie Re: Staircase finish 6Jun 11, 2020 8:13 am Stewie D Wrong! The stringer for the staircase would be 30-40mm in thickness for strength whereas the skirting is only 18mm. Nothing they can do about it although the installer could have run the stringer through higher and made it look like the skirting runs into it. Stewie Re: Staircase finish 7Jun 11, 2020 9:26 am Mine looks just like that,and and it has never struck me as looking unusual (and i usually have quiet a good eye for that sort of thing). If you look closely is looks a bit strange but when you look at the whole timber staircase as a unit it works from an aesthetic POV, My wife is an architect and has also never noticed it as being unusual Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Staircase finish 8Jun 11, 2020 9:27 am brokenstick Mine looks just like that,and and it has never struck me as looking unusual (and i usually have quiet a good eye for that sort of thing). When you look at the whole timber staircase it works from an aesthetic POV, My wife is an architect and has also never noticed it as being unusual Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Staircase finish 9Jun 11, 2020 1:52 pm Actually looking again I do see a difference. On mine the staircase runs higher than the skirting, which is even on both sides, whereas on yours the skirting is higher which IMO does not look as good Staircases and sausages. Should thou wish to keep thy palate sweet for sausages, avert thine eyes from their crafting. 14 4810 Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2859 4 14848 |
