Browse Forums General Discussion Re: Waffle Slab - Large Aquarium 21Jun 04, 2020 10:41 pm They're not legs, more struts that'll span the whole length (the cabinet is part of the display) with a few braces along the length (so could be as many as 8-10 vertical supports. I am with Chris in getting an xray done first and then take it from there. Re: Waffle Slab - Large Aquarium 22Jun 12, 2020 12:58 pm Just a quick update. I managed to find a structural engineering firm that will evaluate the slab and location of the aquarium and give me a report on yes/no. Should have an answer sometimes next week. Speaking to one of the big-aquarium building companies here in Melbourne, they told me they've built longer tanks on waffle pod slabs without any issue, so long as the stand is flush with the ground. Re: Waffle Slab - Large Aquarium 23Jun 24, 2020 3:59 pm Ok. Structural Engineering report is in. And I can quite clearly see now why every house is different. It depends on the thickness of the slab, the slab mesh used, the width of the ribs and the soil the slab is on. Based on the slab engineering plans and the design of the house and where I want to place the tank, it appears that it will cross 2 ribs, with the best-case potential to have a perpendicular rib running length-wise through the middle of the tank. The calculation are based on a weight of 1500kg and all the variables of our slab/soil. Based on the engineer's calculations, we would be safe to do do a 2100x600 aquarium on our slab. But we have been advised not to take it anywhere near 2000kg as that would be approaching the lower end of the variable limit. Re: Waffle Slab - Large Aquarium 24Jun 24, 2020 7:25 pm Hi @Bannor Thanks for the update When it comes to engineering....It's Always sensible to err on the side of caution Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Waffle Slab - Large Aquarium 25Jul 31, 2020 1:32 am I think you should talk with him and if you have some knowledge of construction topics, I bet he might change the way of thinking. Personally, I remember how my aquarium felt dawn after the engineer that works with me, have accidentally dropped the aquarium. My bobbit worm that I bought has been lost, however, I was lucky that it was all covered by the company on which the engineer is working.. It's great actually... The Soil classification has little to do with piers. The purpose of the classing of the soil is to identify the clay content and the "average expected range of movement… 2 9841 consider putting in wall WC instead of robe in the same bedroom, then it might be doable to hook up to the existing piping. 4 6612 4 4444 |
