Browse Forums General Discussion 1 May 28, 2020 12:15 pm I am going to build an Adbri Verswall retaining wall soon. I have decided to go with a concrete foundation as the builders will have a truck on site to pour the extension slab already. Should I box in the foundation using plywood and pegs or should I just pour the concrete in and level it on the day? Diagram of my wall attached. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Retaining Wall Foundation 2May 28, 2020 12:37 pm Just pouring concreting in will do, although in "professional" setting proper formwork is always preferred as only this way you can guarantee correct dimensions and shape. Also, it is always a good practice to use vapor retarder plastic to cover your trench before pouring concrete in. Re: Retaining Wall Foundation 3May 28, 2020 12:51 pm If you dig out the trench accurately and it's clay then all you need is a few pegs in for the correct level for the top of the footing. Doing this and levelling the concrete properly will ensure that you don't have to cut blocks to start your first course. Stewie Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5179 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16140 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6901 |
