Hi All,
Can anyone advise me whether the quote I received for the Piers are reasonable?
8 x 3m x 300mm dia X$303 per meter before GST + $16,362.00
Browse Forums General Discussion 1 May 19, 2020 1:36 pm Hi All, Can anyone advise me whether the quote I received for the Piers are reasonable? 8 x 3m x 300mm dia X$303 per meter before GST + $16,362.00 Re: Piers for Retaining Wall 2May 19, 2020 2:11 pm Winne Huisman Hi All, Can anyone advise me whether the quote I received for the Piers are reasonable? 8 x 3m x 300mm dia X$303 per meter before GST + $16,362.00 Depending on where you are, concrete for your piers will costs around $350-450 plus steel probably another $200. Hole drilling will take around a day max, let's say another $800-1000. Pump rental - $250 per hour max + travel, let's say 4 hours +1 hour travel - $1250. So actual cost to the builder should be below $3K. But on the other side, your numbers do not add up, as 8x3x303 = $7272, not $16,362. Re: Piers for Retaining Wall 3May 19, 2020 2:14 pm Thank you for your reply. The actual area is North Wyong. Re: Piers for Retaining Wall 4May 19, 2020 2:27 pm Sorry, my mistake it should be 18 x 3m x $303/meter and not 8. Re: Piers for Retaining Wall 5May 19, 2020 2:29 pm Winne Huisman Sorry, my mistake it should be 18 x 3m x $303/meter and not 8. Still, only concrete and steel costs will change proportionally, the remaining costs will be the same. This would cost well under $4K to your builder. Re: Piers for Retaining Wall 6May 19, 2020 3:09 pm Thank you so much for the information, Alex. Much appreciated. Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5179 How good is Simeon?! Always taking time to help others out! Wish we were building in NSW and could work together. Thanks for all that you do! 7 6564 DIY, Home Maintenance & Repair That’s very helpful information. Will find out more from there. Much appreciated. 11 13449 |
