Browse Forums General Discussion 1 Jan 01, 2007 6:15 pm G'day, i run a cnc router on the weekends as a bit of a hobby making unique woodwork, but recently ive had a bit of intrestst in branding irons so i have started to make them. if anyone wants a look check out www.cnccreations.com.au.
also i never done it yet but is there any intrest out there in kitcken cabinets that have had images like landscapes engraved over several doors or individal sculptings in the center of a door. has anyone see these done before? regards David Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3501 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10093 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 3597 |
