Browse Forums General Discussion 1 Apr 25, 2020 4:32 pm Hello. We have built a house in queenland and because it was our first home i have absolutely idea about these weep holes. So we had the handover inspections done and it was noted that 2 weepholes out the front of the house were partly covered when they concreted the driveway and front patio. Recommendation by the inspector were to check with the company who did the termite protection if it will cause issues. I have raised the issue with my builder and he said that they run a extra protection on it againts termite. So we moved in. After 6 months we did the pest inspection and i saw in the report that these can cause issues but nothing was mentioned about what is the proper way to fix it. Now im so worried stressed about it Can someone please advise if these 2 weepholes would cause a major issue in the future because i believe its my right to have it fixed by the builder if he need to knock and build that part including ripping the concrete driveway and front concrete rather than not sau a word and then i will have issues in the future Re: Weep holes party covered with front walkway 4Apr 26, 2020 3:49 am Its true that they should be away from the ground so you can see if termites have made a mudbridge into the wall cavity, but by having them partially covered it may also channel water into the wall cavity, stop the cavity from properly draining/drying out and also block ventilation. Re: Weep holes party covered with front walkway 5Apr 26, 2020 7:39 am meeh I have raised the issue with my builder and he said that they run a extra protection on it againts termite. So we moved in. The builder has selectively ignored compliance and only answered your termite concerns. You can download the 3 part National Construction Code (NCC) free of charge. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Weep holes party covered with front walkway 6Apr 26, 2020 9:00 am luxbuild Its true that they should be away from the ground so you can see if termites have made a mudbridge into the wall cavity, but by having them partially covered it may also channel water into the wall cavity, stop the cavity from properly draining/drying out and also block ventilation. Yes and i would like to get it fixed because i paid the right amount of money so i should received a goods that is acceptable Re: Weep holes party covered with front walkway 7Apr 26, 2020 9:05 am SaveH2O meeh I have raised the issue with my builder and he said that they run a extra protection on it againts termite. So we moved in. The builder has selectively ignored compliance and only answered your termite concerns. You can download the 3 part National Construction Code (NCC) free of charge. I am looking at it now. Thanks. Re: Weep holes party covered with front walkway 9Apr 26, 2020 10:23 am Is that a covered area? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Weep holes party covered with front walkway 13Apr 27, 2020 4:39 pm Of interest, another Queenslander has an ironic problem with their weep holes but look at the council's stand! See below. https://forums.whirlpool.net.au/thread/3p8qn2l3 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7092 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5458 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11185 |
