Browse Forums General Discussion 1 Sep 30, 2008 12:32 pm We just took posession of our new house and would like to put some concrete down right next to the house. One bit for a shed and another for outdoor living.
Does anyone know how this will affect the termite barrier. Are we supposed to reroute it around the concrete slab or can we concrete over it. What other precautions may we have to take. Re: Termite barrier and concrete 2Sep 30, 2008 4:32 pm I recently went through this process with my termite company. I have a reticulated system (pipe in an orange sock around the edge of the slab). I needed to cover the pipe with brickie's sand to a maximum depth of 50mm and put the concrete over. They didn't provide a minimum depth. Hi, I had a barrier reef pool installed less that 2 years ago and the gel coat is already fading. The colour is electric grey shimmer which isn’t available… 0 3832 I’m not a structural engineer but I’m free. you still need an engineer for the plans. I only have part of your plans, but you seem to have a 850mm drop from the side… 3 9968 DIY, Home Maintenance & Repair Hi, I have an old fence/barrier made of treated pine logs bolted to plates and these are bolted to very large metal posts/girders. The plates and bolts are rusted through… 0 15124 |
