Browse Forums General Discussion 1 Apr 22, 2020 9:29 am Hi There! We are currently building with Mojo homes. We are just about to lay our slab. I just wanted to get some input where you could recommend putting my air con outdoor unit? We will be having ducted throughout. I personally want the air con on the front of the house because it will not fit down the sides due to the narrow block. My only concern is would it likely be broken into for spares? I have included a few photos of where it could potentially go. Look forward to some of your thoughts/ debates. Cheers Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Where to put my air con? 2Apr 27, 2020 9:44 am We have three split system condensors installed at our house in various locations but I would definitely not put it on the front facade area if I could avoid it. Not really from a theft perspective, just overall aesthetics. Bear in mind you can mount them up high on a wall using brackets. Anyhow I would definitely go with rear living room wall. Just make sure after they rough-in the pipe-work that it will allow them to mount it at the appropriate height. To understand what I mean go and look at other houses with similar outdoor units and understand that the location of the pipework that will ultimately protrude through your brick wall needs to be typically on the bottom-right side of the outdoor unit.....so the location of these pipes is what dictates the position and height of the outdoor unit. Think about if they will use brick wall brackets to mount the unit or place it on a concrete pad? Then think about your landscaping/path heights etc and how this will sit in conjunction with all that. --------------------------------------------------------------------- Check our Homeone build blog here How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5898 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
