Browse Forums General Discussion 1 Apr 19, 2020 10:43 pm Hi all, I have got engineering done for a slab for a house extension. There is an existing slab in place where the extension is going, but it is not up to spec for the engineers to be happy. They completed soil tests and classed my site as H2. They propose the following (below diagram) for a 8.8m long and approx 6m wide slab. The slab will have a single story wooden frame and truss roof over it, it will become a master suite and part of the lounge room. Is this pure overkill for the area and should I go back and try and get this looked at? I have received quotes for this slab for between 14-16k, does this seem right? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Has the engineer over engineered my slab? 2Apr 20, 2020 8:35 am Hi ndossy Welcome to the forum You should always check what's being provided as quotes with what's built on site for non-compliance Here is a quick estimate of the cost, Concrete Volume is approx 14m3 +Labour + few extras Ie 14m3 x $200m3 (concrete) =$2800 + Labour + extras Check with the Councils Building Surveyors as to whether they will accept the concretors certified revised drawings/details OT, It's worth getting the 3D BIM Data and quants before you get trade estimates and then compare Breaking down Reno Costs using 3D BIM Forearmed is Forewarned Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Has the engineer over engineered my slab? 3Apr 20, 2020 11:31 am Yes most likely. There is an alternative and NCC will allow you this: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Has the engineer over engineered my slab? 4Apr 20, 2020 12:24 pm StructuralBIMGuy Hi ndossy Welcome to the forum You should always check what's being provided as quotes with what's built on site for non-compliance Here is a quick estimate of the cost, Concrete Volume is approx 14m3 +Labour + few extras Ie 14m3 x $200m3 (concrete) =$2800 + Labour + extras Check with the Councils Building Surveyors as to whether they will accept the concretors certified revised drawings/details OT, It's worth getting the 3D BIM Data and quants before you get trade estimates and then compare Breaking down Reno Costs using 3D BIM Forearmed is Forewarned Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Chris Depends on the depth of piers (which is not known yet), no? The labour plus pump will be the main cost drivers. Re: Has the engineer over engineered my slab? 5Apr 20, 2020 12:29 pm alexp79 StructuralBIMGuy Hi ndossy Welcome to the forum You should always check what's being provided as quotes with what's built on site for non-compliance Here is a quick estimate of the cost, Concrete Volume is approx 14m3 +Labour + few extras Ie 14m3 x $200m3 (concrete) =$2800 + Labour + extras Check with the Councils Building Surveyors as to whether they will accept the concretors certified revised drawings/details OT, It's worth getting the 3D BIM Data and quants before you get trade estimates and then compare Breaking down Reno Costs using 3D BIM Forearmed is Forewarned Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Chris Depends on the depth of piers (which is not known yet), no? The labour plus pump will be the main cost drivers. I believe the depth is 800mm Re: Has the engineer over engineered my slab? 7Apr 21, 2020 8:54 am alexp79 if it is 9x6, how come it is 164 sqm? Those are engineering properties the The footing, beams ,slab and piers are combined as one solid Individual surfaces can be extracted,eg, Top for reinforcement, sides for formwork..whatever Surfaces along with solids can also be manipulated for simulations, automation, data transfer, etc BTW, I tend to stick to Siemens and Bosch products hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs 3 6412 The engineering is the engineering. It's irrelevant how much material you have. Unless it fits the requirements of your design the engineer can't "make"it work. You might… 7 9693 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15923 |
