Browse Forums General Discussion 1 Apr 17, 2020 4:38 am Hi My land is on a lower side while my backyard neighbour has an elevated level. There is a pile of soil in my backyard (50-60cm cm high) which needs to be removed before I can do the landscaping. But if I remove this pile, the soil from my neighbours house will wash into my backyard from under the fencing. So it will require a retaining wall to stop his side of land mass coming into my backyard. Whose responsibility is that to build such a retaining wall? He is on higher side and I am on lower side? We are in Victoria. From the drawings I could see this soil pile is noted on the builder diagram. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Retaining wall responsibility 2Apr 17, 2020 5:09 am What was the natural land level? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Retaining wall responsibility 4Apr 17, 2020 5:35 am Didn't you take photos? Your builder will know. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Retaining wall responsibility 5Apr 17, 2020 5:42 am SaveH2O Didn't you take photos? Your builder will know. It was a brand-new house but was build by someone else. In the diagram I posted there's a dashed line going from front of the house to the top of where the current soil top level is. Can that dashed line be a representation of the natural land level before the site cut? Re: Retaining wall responsibility 6Apr 17, 2020 10:51 am The diagram indicates that your site is cut below the natural ground level. If so and if you further cut the site to the fence line, you will be responsible for building a suitable retaining wall and bearing the cost of that wall. Your property's lower level will also need attention to drainage. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Retaining wall responsibility 7Apr 17, 2020 11:28 am SaveH2O The diagram indicates that your site is cut below the natural ground level. If so and if you further cut the site to the fence line, you will be responsible for building a suitable retaining wall and bearing the cost of that wall. Your property's lower level will also need attention to drainage. Thanks for the feedback. Attention to drainage??? What do you mean by that? At the moment there's no problem with drainage just that at one spot a water puddle appears everyone when there's a rain Re: Retaining wall responsibility 8Apr 17, 2020 11:49 am I wouldn't build a retaining wall without an ag drain albeit your wall won't be very high but you should get a professional opinion from someone who has seen the site. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Retaining wall responsibility 10Apr 17, 2020 3:12 pm alexp79 and agg drain needs to be connected to the main drainage! But only after passing through a silt pit. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. the conduit would need to be undamaged regardless of what network is in play. The conduit needs to be able to have fibre run through it. NBN and Opticomm are just… 4 2960 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 6031 |
