Browse Forums General Discussion 1 Apr 10, 2020 11:20 pm I'm looking to build a 0.8m high wall that's about 10 meters long using left over bricks from my build. Options I'm thinking of are; 1. Double brick wall 2. Single brick with steel bars in between the bricks every few metres apart and founded in the concrete base 3. Single brick wall Re: Retaining wall build advice 2Apr 11, 2020 8:43 am If you are set on bricks? Then you will need 4. Cavity fill concrete, steel reinforcement, brick AJs, with footings ,etc,etc BTW photos help others Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Retaining wall build advice 3Apr 12, 2020 10:20 pm StructuralBIMGuy If you are set on bricks? Then you will need 4. Cavity fill concrete, steel reinforcement, brick AJs, with footings ,etc,etc BTW photos help others Cheers Chris Thanks StructuralBIMGuy. So I take that as option 1 with cavity fill concrete, steel reinforcement, etc..What is brick AJs? Re: Retaining wall build advice 4Apr 13, 2020 7:38 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15607 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 45705 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6888 |
