Browse Forums General Discussion 1 Apr 10, 2020 1:28 pm I am just wondering how you clean your gutters ? I have a very narrow gap above gutters between the house and pergola. The gap is 2cm wide and I cannot remove leaves from it. Other gutters are not wide either. They are around 5..6cm wide so I am really struggling to remove leaves from them as well. Thank you. Re: How do you clean gutters ? 2Apr 10, 2020 7:34 pm I would be going for gutter guards to avoid the cleaning. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: How do you clean gutters ? 4Apr 11, 2020 10:19 am If you have a pressure washer these are a couple of attachments that will clean the leaves out. https://www.bunnings.com.au/gerni-15m-drain-and-tube-cleaner-accessory_p6270544 https://www.bunnings.com.au/karcher-10m-pipe-cleaner_p0097290 Would need to be used with care as
The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: How do you clean gutters ? 6Apr 14, 2020 4:57 pm I guess you already get the solution that you want for. If not, At first, you need an extendable ladder. Then use a pressure washer because the gap is too narrow. Re: How do you clean gutters ? 7Apr 16, 2020 10:58 pm Foma2 I am just wondering how you clean your gutters ? I have a very narrow gap above gutters between the house and pergola. The gap is 2cm wide and I cannot remove leaves from it. Other gutters are not wide either. They are around 5..6cm wide so I am really struggling to remove leaves from them as well. Thank you. Hello Foma2, I'm assuming the pergola is an add-on possibly of plastic roofing. We have systems for cleaning that out including moving the edge tiles and even unbolting the roofing so we can lift up the sheets to get in. There's usually a way. Hope that helps. Leafbusters 1300 GUTTER Looking to start the journey of becoming an owner builder in SA. Feeling pretty (overly) confident on the building and construction details, but really struggling to find… 0 8397 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6626 A question. Im in Queensland and building a new home. We managed to reach practical completion 6 weeks ago but we haven't heard any date for handover yet. Who should we… 0 5800 |
