Browse Forums General Discussion Re: How do you clean gutters ? 2Apr 10, 2020 7:34 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: How do you clean gutters ? 4Apr 11, 2020 10:19 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: How do you clean gutters ? 7Apr 16, 2020 10:58 pm ![]() I am just wondering how you clean your gutters ? I have a very narrow gap above gutters between the house and pergola. The gap is 2cm wide and I cannot remove leaves from it. Other gutters are not wide either. They are around 5..6cm wide so I am really struggling to remove leaves from them as well. Thank you. Hello Foma2, I'm assuming the pergola is an add-on possibly of plastic roofing. We have systems for cleaning that out including moving the edge tiles and even unbolting the roofing so we can lift up the sheets to get in. There's usually a way. Hope that helps. Leafbusters 1300 GUTTER Re: How do you clean gutters ? 11Jul 09, 2024 12:06 pm Do you have a picture? What type? Ours have a clip every metre or so I can unclip and pull the fascia back to clean. https://encrypted-tbn0.gstatic.com/imag ... coG38_2w&s I have stone pavement (?) in my backyard around the pool. I have not tended to them and so there is moss growing on them. I intend to clean them but was wondering what the… 0 17348 For the gum tree stains you'll need to use a chlorine based cleaner to remove them. Something like this will work pretty good: https://miteq.com.au/masonry-cleaner-303/… 1 12928 ![]() They should have been doing a soft wash to your house, not blasting it with 3000 psi. I am pretty confident that windows are not designed to withstand that force As … 2 10079 ![]() |
