Browse Forums General Discussion 1 Apr 09, 2020 7:30 pm Looking for recommendations for builders, renderers? plumbers....melbourne south east. I have quite a fair bit of work that needs to be done, bathroom reno (I want to remove the tub) few cracks around the walls cabinets stuck windows overall paint Restumping has just been completed, turns out previous owner chose to render over & now that it's level - the render is approx 5cm off where it used to be.... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Restumper tells me it's not a structural issue, but it doesn't look good....any ideas? I'm not sure if I should leave as is, or ask someone to possibly patch up the bottom? This extends around the house. Thanks! Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 15812 How much are you ahead in payments compared to where the build is at? Have you fully drawn down the loan? 5 11934 Mofflepop, Are you building around Qld Manly? Building & Legal is a partnership between a construction guy and a construction Lawyer. Construction: we have… 9 25595 |
