Browse Forums General Discussion 1 Apr 08, 2020 11:41 pm Have recently completed a double brick, timber roof frame with Colorbond roof cover dwelling in Perth with a reputable builder. The engineering detail provided for the roof frame required a 70mm x 45mm MGP10 wall plate. Have recently noted on inspection of the roof frame that a Wesbeam E-Plate has been installed that measures 83mm x 28mm. After investigation I have discovered that Wesbeam no longer supply this product as the reputable builder no longer installs this product and the builder has gone back to using the standard 70 x 45. I am assuming there was/is an issue with this product and Wesbeam have not been able to provide certification that the product conforms to NCC/BCA. Are there any builders or roof carpenters that are familiar with this product and any comment on the fact that a different material has been used that was specified in the engineering detail. Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Roof frame construction 2Apr 10, 2020 10:28 am RexPark After investigation I have discovered that Wesbeam no longer supply this product as the reputable builder no longer installs this product and the builder has gone back to using the standard 70 x 45. I am assuming there was/is an issue with this product and Wesbeam have not been able to provide certification that the product conforms to NCC/BCA. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey rexpark welcome to the forum Then the wall plate is non compliant if it is not as per the engineers details The builder will have to go back to the Engineer and have the alternate Wall plate accessed and Certified as an alternate solution or replaced I suggest you also have the wind loading and connections assessed Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Roof frame construction 3Apr 12, 2020 12:16 am What is that photo showing? That looks like it's in the roof structure not the top plate? Re: Roof frame construction 4Apr 14, 2020 5:25 pm StructuralBIMGuy RexPark After investigation I have discovered that Wesbeam no longer supply this product as the reputable builder no longer installs this product and the builder has gone back to using the standard 70 x 45. I am assuming there was/is an issue with this product and Wesbeam have not been able to provide certification that the product conforms to NCC/BCA. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey rexpark welcome to the forum Then the wall plate is non compliant if it is not as per the engineers details The builder will have to go back to the Engineer and have the alternate Wall plate accessed and Certified as an alternate solution or replaced I suggest you also have the wind loading and connections assessed Cheers Chris Thanks Chris Appreciate your comments. Did not consider the connections and wind loading. Cheers Re: Roof frame construction 5Apr 14, 2020 5:29 pm Doozer1905 What is that photo showing? That looks like it's in the roof structure not the top plate? The photo is showing the wall plate where it spans the fire place. I had easy access to take a photo as the fire place has not been installed. Generally the wall plate has been used everywhere else as per the attached photo. Appreciate you taking time to comment Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Roof frame construction 6Apr 15, 2020 7:23 pm I like to think the engineer would be able to adjust design to match. It is a pitching plate on a brick wall. But it will be up to the engineer to determine that. Registered Building - Always happy to help where I can and simply loves the game. DM me if you need help in VIC. This is 100% true. You can not hang anything on steel frames. very frustrating 8 8023 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28320 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4458 |
