Browse Forums General Discussion 1 Apr 06, 2020 10:59 pm Hi guys, New to DIY, bought my first home about 3 months ago and doing a lot of the renovations myself, I'm seeing light at the end of the tunnel now as far as finishing up and finally buying some furniture for the place. Its been a great experience. Tonight however I ran into an issue I hadn't thought about at all, and that is mounting the tv to a wall with a pocket door. I'm currently trying to figure out if I'll need to remove the door itself before the flooring guys come to install the laminate flooring as well as when I paint it. But my problem is if its a smart idea to mount a tv to this wall? I'm certain it will be a larger tv (70 inch +) as the couch will be a good 14 feet away on the other wall. (Where i took the picture) I havent found any info regarding this at all on youtube or in general, thought I'd ask here if anyone has experienced this. Attached picture, any information would be greatly appreciated! Stu Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Mounting Tv on pocket door wall 2Apr 06, 2020 11:32 pm Not sure whereabouts you plan to install on that wall but the cavity will only extend through to the middle of the paint samples on the wall, so there should be plenty of opportunity to pick up studs next to that. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Mounting Tv on pocket door wall 4Apr 08, 2020 10:54 am are you sure that's a solid wall to mount your TV? if its not, there gonna be many problems after.. there's a TV holder which can move your TV on the shelf or you can just ask the TV seller to order a spical holder.. if you want to mount TV on that wall, that may help micwallpaper.com.au Picture your wall to a view Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5818 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5105 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6328 |
