Browse Forums General Discussion 1 Apr 06, 2020 9:06 am Such a manual gate will cost me about $4,500 fully installed and in alu, so I decided to go partial DIY. The dimensions of the alu RHS are as follows and are suggested by commercial gate manufacturers: Bottom post: 100x50x3, 5600 long with a 400mm tail for a possible motor installation Verticals and top: 50x50x3, five verticals, clad horizontally either with 16 of 65x15mm thick wooden boards or alu slats at 65x15mm. The gate alone without cladding with those dimensions and in steel RHS of same size weighs about 88kg. Alu makes it about 15% dearer, so I am looking at getting it welded in steel and I am wondering if I can get away with 80x40x3 RHS for the bottom and 40x40x3 for the verticals and horizontal top? A tricky question as you either have to be an engineer with a "black belt' in calculating deflections or you have such a gate in steel for a two-car wide car port with a 5400mm wide opening? Re: 5.6m x 1.6m Sliding Gate-RHS Steel Suggestions, Please! 2Apr 06, 2020 9:40 am Hey domwild Try Midalia steel fencing and Gate for materials For Calculating deflections here Design Capacity tables I've got a standard design somewhere just can't locate it atm. Ma-a-ate (midalia) should be able to assist Cheers Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi, Building a new place and I have limited space from garage to fence. 3130mm width, then opens up over 5000mm once I pass tmy garage. I need a fence that goes from… 0 3325 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14458 I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 12130 |
