Browse Forums General Discussion 1 Apr 04, 2020 9:57 am Re: Under window rubber strip 2May 02, 2020 9:26 am From what I can see in the image, it would appear as though the windows have been replaced at some stage. That is a sill flashing, and yes it it important as it stops moisture tracking back into the house that runs down the frame or glass. It would normally be tucked in behind the first board under the window during original construction. Are they essential? Yes Can they be replaced? Yes, but you would have to pull out the window to do it in line with the requirements. They have to allow moisture to drain past the cladding, which is probably why its like it is, because otherwise, all the weatherboards would ave to come off to fit the windows. Hi everyone, Just wondering if anyone has switched from a small square tile insert or normal square waste to a strip drain at all, and if so did the plumber or diy-er… 0 13127 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10128 |
